PLC technical inquiry
Thank you for correcting my terminology and validating the concept I put forward. The nearly unanimous answer of "splitter," had me wondering if I might be guilty of some Mickey Mousery. I've done this several times and never had a problem. And I've seen it done by others too.
There are some scenarios where it wouldn't work, but that's why I prescribed the voltage checks. If it won't work, then it won't work, ever. If it will work, and it worked on day#1, I don't expect that it would "eventually" affect the performance. What kind of long-term degradation are you expecting this to cause?
I just afraid because the application itself is critical and bad consequences may happen to the equipment if any mistake happened at anytime. that why I must apply the best and more stable solution not the easiest one. anyway I really appreciate your help, your tip was extremely precious to me.
Yeah, I get it. Purchasing a product that says on label it does what you want, does give you a warm fuzzy when the stakes are high. Well good luck, hope all goes well!
A dual 10k pot ?
You are right that if they are powered from the same place it shouldn't matter... but what if one channel kicks the bucket and affects the voltage reading on both?
I was going to say that sharing the signal through the network could go against best practices depending on what the signal is, but being a voltage signal I don't think this is the case.
Below are the few details for your reference: B&R PLC Module 2005 CPU – CP152 with APM (Application Memory) Module ME Power Supply – PS477...
1,556
i am using PLC of B&R its CPU is CS0104100242. It is showing Error 23 and when i reset this error its cpu shows "INIT" and again it shows error...
1,871
Hello everyone on PLC talk. Im new here, so i will be humble and was wondering if anyone have a complete description on the simatic s7-400 PLC...
2,354
Hi everyone, I'm newbie to plc our plant has Simatic S7-300 cpu 315-2DP and a tp270, SM321, SM322, SM331 the technical support is in another...
4,021
Sub: Technical support for Omron PLC (Sysmac: C 60 K) I would like to replace an outdated Omron PLC (Model: Sysmac C60K) with an Allen Bradley...
15,505
