PLC to Web page
coda9753
Aug 2005
Southern Ontario
Wow i'm really inquisitive today.
I'm trying to get data from an AB processor to a Web page using OPC or the like. And actually i know how to get data to an Excel spreadsheet or for that matter VB. But i can't figure out how to take it the next step into a web page.
I know AB has modules you can buy to do similar functions but i'd like to do it through code.
The PLC i'm using is a CompactLogix.
HTML Table
Sometimes when I want to post an excel table to a web page I will just put the data to a simple text file in HTML table format. That way it will look just like it does in excel without having excel. You can do a search online for HTML tables its not hard at all if you can work with files in VB. If this sounds like it will work I can post some samples.
No i'm not sure if that is what i'm looking for. End result is i want live PLC data inside a web page. The only reason i mentioned the excel example was to show that i can extract data using OPC/DDE.
Really what i think i need is a way of getting OPC data into a web page, cause i can get the data into OPC.
But hey thanks for the reply i appreciate it
If you want to program something yourself I would look into ASP.NET You can program ASP.Net applications in VB.
If you are looking for something off the shelf, Wonderware has application called SuiteVoyager that can port InTouch windows to HTTP.
Some options
Check out www.ergotech.com as one option.
There are also third party products that connect PLC's to the Net and then you write your code in the web page, or you may be able to find code snippets on the net or in articles that you can put in your page. There are also products for purchase that do this, but they are quite pricey.
If you don't need the OPC layer for something else, it is often extra work to add it and extra $$. There are options that don't require it.
In our application, we use a SoftPLC (rather than an A-B) and we have a routine in the PLC that can read/write directly to web pages AND a SQL database over the ethernet using Java code that runs in the SoftPLC.
Hi PLC talk people, I have a beginner question. I am looking at requirements to build a cloud hosted web application that can connect to a PLC...
2,889
Hello all, I am currently running a program from an S7-1200 and I am using TIA Portal v17. I have created a user-defined web page to eliminate...
1,570
Hey all. We have a Schneider LMC058 motion controller on a machine at work. It went out and we received a replacement controller. When I load...
1,719
Dear forum members, I have a special request, I need to send data from PLC to the web. They will be stored in the database and processed...
6,063
Hello, I am new in the field of PLC. Currently,i am using WAGO PLC 750-352 and I want to send digital data from my plc to server which is...
1,938
