PLC Training
gilnutz
May 2007
Marysville
Hello,
I work for a Water District and we are going to be needing some people to maintain our SCADA system. I have about a year to prepare for this demand. I know nothing about PLC's and want to learn everything. I have worked with computers for a long time and have always like electronics. I am going to take an on line course through George Brown College. It's the best thing I could find that offered some quick and convenient training. I also want to make a test bench at home. I have an irrigation system at home and thought about making a PLC to control that and adding rain sensors to make it more complex. What equipment do you think I should try to find. The PLC's my work uses are AB's Controllogix, PLC-5 and SLC 500. I look forward to your replies and thanks in advance for your assistance.
Billy Gilbert
Contact your local distributor, they probably can provide some training for a fee. We work with ours all the time for training.
Who maintains your current control systems? Anyone?
What are you using for SCADA? You'll need training on databases and other software that you are using to aquire data. There is a lot to learn!
At the very top of the page is a link: Learn PLCs. Phil has put together some great introductory tutorials and other resources to learn from.
After you have been through that, then check here for the Hugh Jack book. http://forums.mrplc.com/index.php?download=156 This gets more technical and is not for the brand new beginner.
At some point you are going to have to get some hands on training. This is where you will want to contact your AB distributor to find out about training in your area.
Last, for the best training there is, check out the training courses taught by our resident Guru, Ron Bearufort at http://www.ind-info.com/
So is your SCADA system going out to bid? I know a great company that handles just about all your needs in the SCADA / PLC department. It's the company I work for so I am a little biased.
You can look us up on the web at http://www.dcreng.com/
Just a little help if you need it.
Billy
IF you are from Marysville Washington, then I would recommend looking into North Seattle Comm College. They teach Allen Bradley (Rockwell). I took six months there (two semesters). I was able to design my own curriculum and learned a lot. The cost for one semester is nearly that of only several days from a Seattle vendor. The person to talk with is Frank Jump.
Dan Bentler
Hello, Im looking to train myself up in PLC's and VFD drives - add another string to the bow as it were. We use them at the company i work...
348
I am working on setting up my own 1756 B series PLC rack, power supply 1756-PB75 /B, 1606-XLS480E -redundant 24 DC power supply, controller...
4,319
Anyone have good recommendations for a PLC training board/console? Something that could be used for in-house training refresher course. RS Logix...
2,878
Hello all, I am starting to consider a change in work and am looking for suggestions on training. I have designed and programed 3 units that I've...
2,139
Hello all, I'm interested in getting an on-site siemens plc trainer to my facility and I'm not coming up with any good results google searching...
2,590
