PLC5 Amber Force LED
Mar 2004
55
I have a PLC-5/80E/E that has a steady force LED illuminated. There are NO comms either from the DH+ or the RS232 ports. The Processor LED is steady red. I've tried leaving the power off with the battery disconnected overnight. However, the problem still exists.
I took the CPU board out and installed it in a PLC5-80B/E just to see what would happen. The CPU appeared to boot but the Processor LED blinked red/green indicating it was trying to flash and there were still no comms. I let it go for about 10 minutes with no change.
Has anyone run across this problem? It looks like someone shut down the CPU with the forces enabled but should that alone disable the DH+ and RS232 comms?
Any help appreciated.
CTG
Force LED
solid red proc ... download program
forces ... sfc or forces enabled in project loaded.
and as for swapping processor boards between processors... voided warrantee...fingers in ears la la la.
No, it shouldn't, otherwise there is no way of removing forces. I have no experience with PLC5 however, but my (limited) knowledge of SLC5/03 and CompactLogix makes me think this way. Anyone who can confirm my thoughts?
Kind regards,
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
166
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
384
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
539
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
530
