plc5 barcode scanner
bernie
Dec 2005
michigan
18
does anyone know a simple way to allow a barcode scanner to introduce ascii to a plc5/80 e
currently it is done using a sql server
trying to make it stand alone and its been dumped on me to make it work
using channel O for scanner
scanner is datalogic om type
is there a ab knowledgebase or any sample rungs that i can test and than change as needed to allow for this transition
thanks
any and all help is appreciated
:geek:
I am a student at Utah State University and am working on a project that involves a PLC-5. I am hoping some of you won't mind offering some...
6,345
I need to link a PLC5/30, Panelview Plus 700 and a barcode scanner (currently RS232). My original plan was to use RMTIO between the PLC & PVP...
8,764
help!!!! using a 1734 232asc point i/o module over devicenet back to a sdn module in the plc5 rack.... reading barcode back to a plc 5 (sdn to...
37
6,723
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
158
