PLC5 Cold boot woes
SteveD
Guest
S
I have a plc5/40 processor that when cold booted will not scan its remote I/O. If I take the processor from REMRUN to Program and back to Run mode....everything is ok. After a cold boot the processor will squawk no faults..the only thing I have found different is the Remote I/O racks output cards do not show active on there faceplate. If I go to program mode either via RSlogix or key switch...it kicks it in the pants and it starts scanning remote I/O very happily...any ideas out there?
Steve
PLC-5/40
SteveD
If I remember correctly you are describing the Start-up protection function of the PLC-5/40. Check out documentation on user control bits S:26/0 and S:26/1, they define how the processor starts in the RUN mode after power loss (Cold Boot). I think if the power is restored when the Processor is in the RUN mode status bit S:11/5 (Start-up protection) sets if S:26/1 is set. If S:26/1 is not set there is no protection, if S:26/1 is set there is protection.
Read up on Start-up protection to confirm what I have told you.
Hope this helps
Roger
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
166
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
383
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
538
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
530
