plc5 ethernet module uptime
lightning1
Oct 2009
nashvegas
17
i have a plc5/80ethernet module.the issue i'm having is sometimes a 3rd party software we are using for mapping product stops communicating.they are saying it is a plc issue.the plc stays in run.typing in the address to the processor in the web brings up the rockwell provided page and it shows uptime of processor.my question is if we loose communication even if the processor is running correctly with no faults will the "module uptime" on that page change?or does it only change if the processor is powered off?thanks
I'm not specifically certain about the PLC-5's embedded webpage, but on all other RA products that have an embedded webpage with an Uptime counter, the value increments starting from power-up.
The fact that the HTTP server is working doesn't mean for certain that the CIP or CSPv4 protocol servers are working.
To resolve questions of "which component stopped working" effectively, protocol analysis is the only way to go. I do this sort of thing with mirror-port Ethernet switches and Wireshark software often.
our i.t. department has swiched to another data connection yesterday they said it was "saturated".it has worked with no issues yet last night and today.thanks ken i will suggest to them your option if issue comes up again.thanks
Can I use a 1785-ENET on a older PLC5-40 that does not support ControlLogix message to enable me to add ControlLogix messaging? Providing that the...
1,248
Noticed on the PLC5 webpage there are a number of collisions reported. Reset the counters and can watch it rise. This PLC5 is only...
1,512
I have an old system with a 5/25 and lots of empty slots in the chassis. The CPU has no channel 0 port. I want to get this CPU on Ethernet for...
1,477
Yesterday I was working with an Allen-Bradley Controllogix and a Compactlogix. I was using a MSG instruction to read from the Controllogix via...
1,131
Recently we had a "Made in China"portable line installed Weiview TouchPanel MT8102iE, it has capability to connect CompactLogix and ControlLogix...
3,807
