PLC5 Isolated Output Card Question
Jamokey
Apr 2020
Alberta
I had a customer ask me to investigate what state a digital output would be in a PLC5 if the the processor faulted or was put in program mode.
It has been a while since I have worked with a PLC5, so I cannot remember. I think it holds last state, however not 100% sure. Maybe someone can tell me exactly the state of these outputs may be. Thanks.
Normally they would stay in their last state
If I remember correctly there is an option to set to ON or OFF if the communication is lost or on a fault check the manual
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
153
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
367
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
520
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
517
