PLC5 Themocouple input card 1771-IXE
You don't set the scale. You just configure the card for the type of thermocouple that is connected to it and the raw data will be in degrees
"F" or "C" directly. see sample config below
also links for the manuals
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1771-in049_-en-p.pdf
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1771-um658_-en-p.pdf
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
154
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
373
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
521
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
519
