PLC's with Virtual Axes and step/direction motion output
Tomfoolery
Dec 2015
Atlanta
I have a unique material handling need that can be addressed by combining a conveyor's belt motion with a linear slide that moves the conveyor's frame position. This will give me a way to manipulate what is happening on top of the conveyor separately from what is happening on the underside of the conveyor (it would take a very long explanation to describe why this is a good thing and how it would be used, so you'll have to trust that this is a useful application of motion control).
To make this work, I need a PLC that:
1) has two virtual axes
2) has two real axes of motion control output
3) has the motion output in the form of step & direction
There will be a separate trigger input for each virtual axis. Each virtual axis might have a different triggered motion (example: a three" index for a trigger on VM1 or a 36" index for a trigger for VM2).
The conversion to the real axes would be a combined gearing of the activity of the VM's. For example: Motor 1 = 0.75*VM1+0.5VM2. This is the same kind of combined gearing that is required for H-bots.
I want the step & direction output so that I can easily mock this up with steppers and then advance to Clearpath Servos to commercialize it.
I looked at Delta, but the outputs appear to be analog 0-10VDC. I looked at Panasonic, but it is unclear whether they can handle two simultaneous VMs. Allen-Bradley doesn't have step & direction without paying a lot for AMCI cards.
Any suggestions as to what PLC's might have everything I am after?
Look into the Mitsubishi PLCs with the simple or advanced motion modules. Just not sure of your #3 requirement.
Hi everyone, I am a starter with PLC programming and HMI. Allen bradley to be specific. I have RSLogix Micro, Studio 5000 and Factorytalk View...
39
22,979
Hello, I am setting up a virtual machine with PLC monitoring software. For serial/USB connections to the PLC's, there is no issue connecting a...
1,678
Good day dear Experts! Is there a way to simulate a communication between a S7-1200 PLC and python script? I know this is possible physically...
3,561
we are trying to go online, with RSLogix5000 v17, to access a Rockwell plc ControlLogix. All the softwares are running on a Virtual Machine...
5,589
Has anyone been able to connect their PLC to their software on Virtual Machine? For some reason on my regular host machine the PLC connection...
4,625
