Let's clarify a few more things:
The 1747-PIC/AIC+ driver will always be available for configuration, no matter what service pack you are running. It just won't work if you have the Windows XP Service Pack 3 "serenum.sys" driver installed.
The DF1 Point to Point driver with "SLC/MicroLogix/PanelView" as the Device Type works like a two-node network where RSLinx is Node 0 and the SLC is Node 1.
The DF1 Point to Point driver with "1770-KF2" as the Device Type works like a multi-node network where RSLinx is Node 0 and it tries to browse multiple other Nodes. If the SLC is set for "DF1 Passthrough" then it compares the destination address on every packet to its DH+ address (not its DF1 address).
If the DH+ address of the SLC matches the destination address, it responds to it. If not, it passes the packet on to the DH+ network.
