Pls. introduce the HMI for SIEMENS S7 200 (PPI)
somnamon
Jun 2012
Loei
Pls. introduce the HMI for S7 200 (PPI)
or if i have proface 4000 series , can it connect to PLC SIEMENS S7-200 via PPI Port(y)
When you say introduce the HMI are you looking for suggestions as to what HMI to use with S7-200?
I have successfully used AGP 3200 to communicate with a 200 series plc.
From memory you select "MPI" on the proface setup but select "200" as your plc type.
Check with your Proface agent if you need an "MPI adaptor plug".
I also use a length of profibus cable with two d - connector plugs with integral terminating resistors between plc and screen.
i want the cable to connect PLC FUJI MIREX- F Who ever used, and pls. tell me how i order it , or pls. tell me the part number of the cable thank you
3,955
Hi im doing a energy saving program for a lamp. And basically the instructions are to turn off the lamp if is not being used ....... but with no...
1,496
Looking to get a program off of an older Eberle Vario P-621 PLC. I don't know much about Eberle, but some quick research brought up the idea of...
1,089
[IMG]https://www.img.in.th/image My timer cant run, please help me
3,270
Hi, I am fairly new to PLC programming and in this project i have to understand the electrical circuit and implement the logic in PLC. The only...
1,838
