PLX31-EIP-MBS4 Ethernet Connection problem
awalasheen
Apr 2018
Khobar
Hello guys,
I have a new PLX31-EIP-MBS4 and I wanted to configure it, connected the power terminals and Ethernet cable to the gateway and other end of the Ethernet cable to my laptop.
However, it seems that that Ethernet connection isn’t established as it gives me “Cable unplugged “.
I tried p2p and crossover connection for Ethernet cable but the same.
Any ideas?
Thanks in advance
Your pictures did not show.
https://www.prosoft-technology.com/Products/Gateways/PLX3x/PLX31/EtherNet-IP-to-Modbus-Serial-4-Port
I would check to ensure that the unit is powered up correctly.
The above link will show you the setup procedure.
This may help you out.
Regards,
Thank you gclshortt.
the ethernet LEDs are always off and all serial ports LEDs are continuous Amber.
I followed the guide but nothing.
I checked the led status in the manual but i never found any explanation for "continuous amber" for serial ports LEDs.
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
825
Dear all, Can any one share the procedure how to configure Allenbradley PLC as modbus TCP server with DCS through Prosoft PLX31 EIP MBTCP
2,164
Hello, I've recently decide to try using a prosoft gate to bridge handshakes between two of our processors. Reason being is one is profinet and...
1,374
Hi Experts, Sorry as I am new in working with Allen Bradlly platform & Modbus Communication :bawling:. I have a redundant system ( Control Logix...
5,133
Working on setting up an Ethernet module to handle messaging between an AB Contrologix PLC and a Siemens PLC. I have the device setup on the...
4,438
