GE PAC SYS RX3I to AB via Prosoft PLX31-EIP-PND
Cookz615
Feb 2017
tennessee
18
Hello,
I've recently decide to try using a prosoft gate to bridge handshakes between two of our processors. Reason being is one is profinet and the other is AB. After looking at the setup tutorial on prosoft's website it seems easy enough but my problem is that I am still really green in this field and am unsure if I need to use the Siemens TIA software in the tutorial being as Im connecting to A GE RX3I processor. Just figured I would reach out to the Guru's for some wisdom. The TIA software looks awesome but im not sure that I can use it for what I am trying to do and what software I need if not. Any help or suggestions would be greatly appreciated. Thanks!
I can't answer directly however, don't think of this as connecting to an RX3i, think of it as connecting to Profinet. Unless of course you end up using a different protocol that's more specific to the RX3i. i.e. SNTP, EGD, OPC-UA, etc.
Hi All, I am trying to program some new Versamax micro PLCs through PAC using some programs saved in our archive however whenever i go to import...
125
Hello, I am kinda new to automation, I had an issue with 1743-EPAC which supply's 13 IO , when we inspected it there was a short circuit...
144
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
388
Hello everyone, I am not a programmer, but I can do some simple programming. So now I want the time to be recorded every time a pump turns on. I...
35
2,712
Hello everyone, how can I see in machine edition (in 1 overview) which variables are not in use? When I create a new variable it continues with...
567
