PM received, forwarding to the forum.
GregPLC
Oct 2002
Milwaukee, WI
342
This was a PM I received from a guest, I guess he needs help.
Re: hi
(Quote:)
GregPLC wrote on Today 10:57 PM:
Sure, post it in the forum, and I'll be glad to try.
(Quote:)
necyil wrote on Today 04:52 PM:
hello may i ask you some question about plc?
hello
i am necyil..from Turkey
i would like make a plc program. can u help me?
For Rolling Mill
i need make contro Coiler Torque and speed. I have line speed and coiler speed.
I think for this i need calculate coiler diameter.
May u help me which way i make this
Many thank for your help
Necmettin YILMAZ
Greg:
You are in a very elite group that is considered around the world as the best of the best.
You should be very proud.
Also, when I can get TestSubject down to Starved Rock, along with as many others as will come from chicago, milwaukee, and points surrounding, you have the option of buying the first round.
Back to the post... I don't think the coil diameter is a factor here. Speed and resistance should play the big part of determining the torque, I believe. But I have been removed from this type of application for many years.
regards.....casey
Torque would be a factor of diameter, width of material, and density of material.
So, wire would just be density and diameter. sheet steel would add in width and, to a lesser degree, material thickness.
Necyil, what are the material specs? What are the speed of the line specs. And what is the required accuracy (1mm or .01mm)?
Were those the only files? Megabasic files have the suffix .bas You can probably get along without PCOP. Termf is sufficient to do whatever you...
183
I received this by PM. I prefer to keep the discussion on the forum. Hello ! I managed to connect to PLC GE 90-30. I don't know the Proficy...
1,160
I just got this via PM I prefer to keep the discussion on the forum. Can you be a little more specific? What is the nature of your trouble? Are...
670
I got this PM this morning. I prefer to keep the discussion on the forum. There are two default passwords in a PanelMate. I would try them...
874
I got this request via PM. I prefer to answer in the forum instead of in private. Hello Steve! How are you? Hope you are good right now. I saw...
871
