PM3K to ControlLogix L55 on DeviceNet
godfrey
Apr 2002
Charlotte, NC
412
A colleague of mine helped me set up a message instruction in RSLogix 5000 V15.5 to get data from a power monitor 3000 thru DeviceNet. It currently works fine for one monitor. Now I need to add eight more monitors to the network. He said he used something called "DeviceNet Tag Generator for RSLogix 5000" to automatically generate tags. I've tried searching for this but have come up empty. Have you heard of this?
The Tag Generator utility comes with RSLogix 5000 v16.03 and with RSNetworx for DeviceNet versions 7.0 and 8.0. It's also downloadable from the MySupport website.
Here's a FAQ on the tool itself: Answer ID #42125
All the Tag Generator does is automate the process of creating UDTs that match up with certain I/O assemblies and creating logic to move that data in and out of the Scanner's I/O table.
For PM3000, I still prefer to do the work by hand, but the Tag Generator might do some of the heavy lifting.
I'm just beginning to work on setting up about 10 of these on a DeviceNet network. Any chance I can get a copy of your program so I can get a jump-start on it?
Thanks,
Richard
110
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
108
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
237
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
228
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
261
