Point Bus Status in 1734 AENT Point IO.
Jul 2015
Kolkata
Some times in running condition of the PLC, the point bus status become solid red and network status blinking green due to that total system stops..... I ve checked all Ethernet connections also.....there is no problem but if i recycled the power of the PLC then it becomes healthy automatically... I have checked all possibilities mentioned in manual also.
Plz suggest what should I do?
Hello all, I have a couple 1734-AENTR/C modules (revision 6.012) that are connected to a 1756-L73S (Revision 32.011). I have checked the...
2,851
Hi all, I definitely know this is common problem and there are many threads about it and I did read them several time using "search" tool. Also...
16,622
About every 5 minutes we are seeing both network and point bus status lights on our 1734-AENTR blink red simultaneously for about 30 seconds, then...
1,428
Hi, I just bought a 1734-AENT Series C module (Revision 6.01). I am using RS logix5000 and at site we have a running system with control logix...
8,815
Hi eveyone. I need transfer signal from system 1 to DCS via modbus. System 1 only can send 32 bit floating point. DCS receive 16 bit integer. How...
20
10,611
