Point to local file from HMI TAG (FTSE 6.1)
xC0MMAND0x
Jul 2013
Minnesota
265
Here's the short straight to the point version - I need to display a PDF file on a HMI. I'm using FTSE 6.1
I have AcroPDF.dll setup and registered. System is W2K8-64bit.
I made a test display, and I can embed the ActiveX control (Screenshot 1) - it's registered and that's working.
I can see the ActiveX object on my TestDisplay (it show's as a PDF icon). I need to point that to look at a file. The only properties I can see are to look for a src Tag. (Screenshot 2)
I have tried to make an HMI tag that's a string, and link the ActiveX element to point to that - which seems to be working.
I can't figure out the syntax for pointing to a local file. I've tried the following Tags as strings:
\\pcname\shared_folder\test.pdf
\\ip_address\shared_folder\test.pdf
C:\path\shared_folder\test.pdf
Documents\test.pdf (Where Documents is C:\Users\Public\Documents\RSView Enterprise\SE\HMI Projects\HMI_Project)
Any thoughts/ideas? How do I point a String tag to a local file path, and then link that to the ActiveX element? I'm trying to get this working and have tried a lot of different options, but I need some help.
Anything would be helpful.
Thank you!
I solved this!
I ended up using the ActiveX element Microsoft Web Browser.
After embedding that on a display I exposed it to VBA (Right click --> Property Panel --> Expose to VBA - VBA Control).
Then I right clicked on the display itself and added a bit of scripting as such:
Code:
Private Sub Display_AnimationStart()
Me.MicrosoftWebBrowser1.Navigate2 ("\\path_to_share\name_of_file.pdf")
End Sub
Where "MicrosoftWebBrowser1" is the connection for the particular embedded object.
Easy and works perfect! Perhaps this solution will be useful for someone else.
(y)
Hello, I want to connect 1769 L18ER PLC with 8 number of 1734 pont IOs. 24V Dc 8 Channel Sink Input Module: 3 nos 24V Dc8 Channel Source Output...
7,725
TLDR; How to synchronize setpoint values between a local HMI and remote PLC connected by cellular modem, while preserving the most recently...
4,105
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
79
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
117
Good morning, I have a Emerson/GE PLC with Cimplicity SCADA. I need to export data of a specific point/object to a CSV file and load the CSV file...
289
