PointIO 1734-OB8 and E-Stop
jrsnydley
Dec 2014
Minnesota
155
Hello everyone, I am setting up a project using PointIO for the first time. I will be hooking up a 1734-AENTR to a 1756-ENBT module. In my remote IO, I will be using a 1734-OB8. It appears that this module gets its power from the backplane. My question is how do I E-Stop it? On other systems, I have my 24V DC supply run through my E-Stop to the VAC - VDC terminal on my output module. It appears I cannot do that with the PointIO. Do I have to drop power to the entire backplane? I have several E-Stop buttons so I want to notify the operator as to which one is pressed. I would need my inputs to be active in order to do so and dropping out the backplane would inhibit all of my modules. Any ideas or suggestions?
I use a 1734-FPD module to introduce a new power source that separates it from the adapter. It maintains the communications and power associated with communication.
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,052
Hi, I'm having issues commissioning a new PointI/O module (1734-4IOL) on an existing DeviceNet network (1756-DNB). I am adding the 4IOL module to...
833
Hi Experts, I got a 1734-ACNR failed on-site recently. I have replaced it with a new ACNR (node number and chassis size configured) but can't fix...
3,650
We are having some issues with a PointIO module (& maybe more) going into the shutdown state momentarily. This is connected to a 1756-ENBT that is...
3,881
Hello all, I Have a PointIO module with 2 input cards. The Revision is 6.013 and it is connected to a ControlLogix running version 24.11 The...
2,375
