PointIO 1734-PDN DeviceNet Module Issue
Anthony92
Aug 2019
Sydney
Hi, I'm having issues commissioning a new PointI/O module (1734-4IOL) on an existing DeviceNet network (1756-DNB).
I am adding the 4IOL module to a 1734-PDN on a new terminal block on the end. The point IO only has 2 existing cards so this one will be the 3rd. When power cycling the DeviceNet power and PLC the module powers up with a solid green light on module status and solid red on network status. This card is new out of the box so it should initialize with green flashing on the network led? When I scan the DeviceNet I cannot see the new card either (even on the default 63 node address).
However when I swap this card out for a standard 8 DC output card it initializes with green flashing on the network led.
Is there something I am doing incorrectly? Everything is installed right, the existing DeviceNet is still functional and the cards are seated properly.
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,051
Hi Experts, I got a 1734-ACNR failed on-site recently. I have replaced it with a new ACNR (node number and chassis size configured) but can't fix...
3,641
Hello everyone, I am setting up a project using PointIO for the first time. I will be hooking up a 1734-AENTR to a 1756-ENBT module. In my...
1,914
We are having some issues with a PointIO module (& maybe more) going into the shutdown state momentarily. This is connected to a 1756-ENBT that is...
3,881
Hello all, I Have a PointIO module with 2 input cards. The Revision is 6.013 and it is connected to a ControlLogix running version 24.11 The...
2,375
