Polar 155 Cutter Help
yam785
Jul 2004
pa.
153
Is there anyone who has knowledge of the sequence of operation of a Polar 155 cutter. We are currently trying to convert a unit in which the PLC died, to Contrologix, and also use a servo motor to position the backstop. If anyone has any knowledge, about the sequence it goes through to make a cut, or has knowledge about which solenoids control what, or any info at all, I could really use any help possible. This is a machine that was in very bad shape, and all the company which bought it wants to do, is set the backstop to a position, and make a cut. The backstop control is not a problem, but we have no documentation, to explain what solenoid controls what, or info on how the sequence of the cut works. Can anyone explain the process, the hydraulics, cam switches, solenoids, etc. For example, how does the system bring the blade down for one revolution, and then stop it. Also, info on how the safety aspect should work. My boss got us in deep on this one, and I really need to understand the machine. I would never forgive myself if someone got hurt using it, because I didn't fully understand the operation. I would be deeply thankful for any help provided.
Thanks, Bob
Our company in the past has connected the IY4 in a unipolar fashion (signal to In+ and 0V to IN-) and it has worked no problem. We currently have...
1,715
Hi all, Does a 12-bit resolution PLC module have a sufficient accuracy to carry out a standard PIT/FIT processes? I'm looking at a module cut...
2,116
Doing a lot of VFD programming and it got me thinking. What method of direction control do you guys use and why. I usually use unipolar logic...
2,474
I recently heard that using diodes for unipolar encoder connection is a good idea to reduce the influence of noise. The diodes go between A and...
1,554
i want to scale a 14 bit input (0-16383) to 0-3000 scaling ,but winproladder dsnt give a built in function i guess like...
4,850
