Position Control of DC motor in FX-2N series PLC
Afshan
Apr 2012
Islamabad
I am trying to do position control of dc motor. I am using FX-2N series PLC and using PID instruction to achieve the desired control.
Me using high speed counter to measure the encoder pulses. But failed to achieve it.
Can any body help me, regarding PID instruction to achieve the position control of the motor.
Regards,
Afshan
PID controller is sufficient to achieve a positon controller , indeed you need a DC drive besides the PLC as you can't feed the excitation voltage to the field winding to the motor via PLC and the armature voltage also ,but the question is , what type of set point will you use , from encoder or from what?
and inside the DC drive you can perform speed controller optimisation and torque controller and current controller optimisation also
with DC motor i prefer a PI controller
hi guys i saw a good topics here in the forum talking about advanced control thanks to peter and pandiani many thanks to them for their time and...
2,422
Hi Guys Im currently doing a project where i am having move a motor to any given position fwd and rev.I was given a s7-300 plc with anologue in...
15,413
I have a ML1100 PLC and a DC motor with a potentiometer mounted to its shaft. I want to demonstrate positional control using a PID loop(no load)...
4,135
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,922
Hello all, I have an old machine that utilizes two FEAC PC-116-24 controllers used for position monitoring and output to an OMORM CQM1 PLC. I did...
633
