possible to connect to micrologix with PCMK?
vha23
Feb 2003
27
hi, as the title says, i'm in kind of a pinch right now and dont have the normal cable that i would use to connect from my serial pc connection to a micrologix 1500. I do have a PCMK card on hand though, and that cable does fit into the micrologix port. Does anyone know what settings I need to use to make this work? I tried looking on Allen Bradley's site, but this site always seems to be faster. Thanks.
i don't think u can do that. the pcmk card talkd to dh+ i don't know of a way to talk to a seral port.
thanks for the quick replies. it doesn't seem to be possible, at least not easily. i figured i'd give it a shot
You'd have to use the PCMK set to talk DH485 (and the appropriate cable) and then connect to a AIC+ that is cabled to the Micrologix. A very indirect (and more expensive) method to be sure.
It may look like it should fit, but it doesn't!
If you made it fit, then the cable or port or both are likely damaged.
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,078
Hi, I have AB Micro820 PLC (2080-LC20-20QBB) which, acc. to the specs, can be both Ethernet/IP master and slave. I need it to be a master and...
2,228
Hello Guys, can you give me a tip? I am designing a Filter Press Station and I can't afford to buy HMI panels so I am going to use my PC as HMI...
2,079
Hi Gents, this is a tricky one. I am waiting to receive an actual Modicon M340 PLC, but I would like to test my code. Is it possible to connect...
5,178
I was wondering in you could gain access of a plc that is connected by dial-up modem on one end and me through the internet on the other ..is...
2,444
