Power Counter kWh
Hojland
Oct 2006
Langå
203
why would this floating not count.
I know it's something with decimal place to do. It is counting fine, until it comes to five decimale in front ofthe point
Sorry for my bad english:(
32-bit floating point is limited to seven significant digits. It doesn't matter which side of the decimal point.
If you require three digits to the right of the decimal point, the largest value you can accumulate is 9999.999. Once your accumulated value exceeds 10000.00 your smallest increment becomes 0.01.
I feel really, really dumb asking this, but I shall. I am using a Micrologix 1000 to toggle two outputs. I am using a timer to time and it...
1,499
HI All I have Omron CQM1-CPU44 I am writing ladder diagram for semaphores COUNTER, unlike TIMER, don't clear content when power is turned OFF and...
3,373
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
25
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
280
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
63
