I currently have a simple process of a risne return pump running off of a high and low level float. The logic contains an output latch to the drive run/enable relay which is activated by the high float and deactivated by an unlatch which is controlled from the low float........Simple
However I have an alarm sound/light running off the relay out on the drive which is set for OL..........For whatever reason every time the drive turns on and the motor starts the sound/light chirps as if there was an Overload. Am I not understanding the operation of the Relay Out of my drive? Shouldn't it only go off if there is an OL fault?
