Allen Bradley Power Flex 70 VFD fault 85 issue
Dec 2011
Massachusetts
I am having a fault 85 comm. issue on a Allen Bradley power flex 70 VFD, there are two drives rotating on run hours or if one fails, the other will start and run. They are both communicating with an HMI(Allen Bradley panel view. The fault 85 is a comm. failure. There is a flash upload available for the same scenario but for a Power Flex 700,there was an advisory for that but not for the Power Flex 70. I have not heard back from Tech services yet. Would anyone have experianced this particlur fault on the PF 70 and if so how did you correct. Thanks in advance.
yep. but with a devicenet interface. is that what you have?
In our case, the drive firmware (not the dpi device firmware) needed to be above rev 2.001
http://rockwellautomation.custhelp.com/app/answers/detail/a_id/32247
The technote first says it may apply to any 20-comm device, then later states that it has not been seen with the 20-comm-e or 20-comm-c
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
237
Hi everyone. I have an issue with an Allen Bradley PLC model 1769-L30ER. This PLC had a previous program with a different IP address but when I...
527
I have several 5069-AENTR adapters in a system. All of the IO is 24VDC. Can I use the same power supply (24VDC) for both SA and MOD power into...
530
Have some equipment that have the micrologix 1400 1766-L32BWA. all of our equipment in the locations have 208-220vac 60 hz power. Was just told we...
1,748
Hi All, I'm having some trouble on determining the total power consumption of the following I/O modules: 1769-OB32,1769-OF8V, 1769- OW16...
2,637
