I have a drive that keeps faulting when I turn off my pump. At first it was giving me a hw overcurrent so I increased the accel time and it seemed to remedy that problem. Now I keep getting a over voltage or over current fault when I shut the pump off. I have increased the decal time per the manual and still have had no luck remedying the issue. Also if I shut the disconnect off between the pump and drive then rest the fault the pump will restart. If I do not shut the disconnect off the fault will keep happening every time I reset the drive and then try to start it. This is a power flex 400 drive and it is feeding a 30hp motor that is turning a pump. Any help on fixing this issue would be appreciated. Thank you
