power flex 40P encoder??
Adam303
Aug 2009
Chicago
587
Can anyone provide me with a AB cat # of a encoder that can be used with Powerflex 40P. The manual states that PowerFlex 40P will only works with 5V or 12V line driver type encoder, but I'm having a hard time understanding what the LINE DRIVER TYPE ENCODER means. Thanks for all the help.
Has any one used the powerflex 40p with a encoder if so what type of encoder is it? what brand?
hey I have spoke with a AB tech Support and asked them to provide a bulletin number of an ab encoder that I could use with Power Flex 40P. The answer I got was "just look for an encoder that has a differential line driver as an output. So just to answer myself here bulletin number 844a,844B,844D have a differential line driver outputs.
Differential Line Driver: A type of
output driver using two signal lines per
encoder channel. When used with a
differential line receiver, longer cable
lengths and higher noise immunity can​
be provided.
[FONT=Swiss721NarrowSWA,Bold][FONT=Swiss721NarrowSWA,Bold]
[/FONT]
[/FONT]
hello everyone, i would like to explain my problem and see if someone can help me. we have a machine to cut wood, original the aluminium head...
6,423
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
116
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
66
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
127
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
188
