Power Flex 70
the eye
Jul 2009
El Salvador
Hello everyone, I need to know how can i get all the data generated by the drive using a comunication module 20 COMM-R (RIO). I get some data now, but not all.
it is posible set up the memory map of the device so through a ladder logic we can view all the data generated?
or
some configuration of the module that i miss that allows me to do this ?
Hope you guys can give some advice ... Thank in advance
I have use 20-comm boards in the past and the way i get info is either by using datalinks, or using message. In manual Publication 20COMM-UM004C-EN-P - March, 2002, chapter 4,5, you have all you need.
Are you sure you need all the data from the drive in the PLC?
In my experience only about 30% of the powerflex capabilities get used in each application.
Have you looked at the Drive Tools SP - never used it with RIO but might be a better configuration, back up and monitoring package than passing data to CPU?
M.W (www.ac-sys.co.uk)
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
69
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
128
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
190
i have a flashing yellow sts light. "Stop Asserted" message on one of my PF 753"s, but no bits set in parameter 961. The safety circuit tests...
209
