Power Flex .dno file Download
Aug 2011
lahore
18
Dear All
i need help on how can i download .dno file to my power flex VFD & also guide me about the cable through which i can download the above mentioned file ...
regards
to download a .dno file to a Powerflex drive you will need Drive Executive software
As you haven't told us which Powerflex drive you're using or what connection methods you have available, it's impossible to tell you which cable you need.
The only way to download a DNO file to a drive via the keypad is to open it in Drive Executive and enter each parameter one at a time, if you do not have Drive Executive upload the file here and some one can do a print out for you, then you can go ahead and enter each parameter one by one by using the HIM.
Alan
If you have Drive Executive and a 1203-SSS or a 1203-USB you can download to the drive this way, also depending if the drive is on a network you may be able to download it over the network.
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
131
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
73
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
135
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
198
i have a flashing yellow sts light. "Stop Asserted" message on one of my PF 753"s, but no bits set in parameter 961. The safety circuit tests...
211
