you can try this model from puls, it is more square than rectangle. I think you can get up to 4 or so amps and the width or whatever stays at 75mmI am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide.
this is what I have now.... this is ugly and not ideal.
Lol thanksNice SkyCAD drawing!
Do you mean just rotate my existing power supply? or Mount it somewhere else on a horizontal din rail?Is there a reason you can't mount it normally?
Thanks, I forgot to mention I need like 8A to 10A.you can try this model from puls, it is more square than rectangle. I think you can get up to 4 or so amps and the width or whatever stays at 75mm
ML70.100
The ML70.100 is a 72W 1-phase DIN rail power supply. ✓ DIN rail mountable ✓ Compact size: 45mm wide. Learn moreproducts.pulspower.com
not sure what amperage out you need
Thanks I will go lookSeveral of the Siemens power supplies I checked had derating curves in the manuals (rated current vs ambient temp) for pretty much every installation orientation. It's a different curve depending on whether you rotate it 90 degrees left or right from normal, haha. Sometimes you gotta love the German attention to detail.
SIOS
support.industry.siemens.com
Yes, why not rotate it and use a din rail terminal stop to keep it in place?Do you mean just rotate my existing power supply? or Mount it somewhere else on a horizontal din rail?
Looks like not enough space between the wire ducts.Yes, why not rotate it and use a din rail terminal stop to keep it in place?
Ah I see now. Sorry it's been a long day. What kind of amp rating do you need, OP? Maybe something smaller would work?Looks like not enough space between the wire ducts.
To tall that 126mm tall, so when rotated it is too wide. I need <4" so <106.5mm.Traco Power TSP 360-124WR 15A 24VDC Input form 85VAC to 550VAC
