PowerFlex 4 to vary pump output pressure
jonmoga
Sep 2013
Auburn, CA
Hello,
I have a glyco system that chills several product tanks. We have a problem with over presurizing the glycol system when only a few tanks are on. I'm hoping to vary the speed of the pump using a AB Powerflex4 and a presure transmiting using the 4-20ma to control the speed.
Here's my questions.
How do I configure the VFD to vary the motor from an inverse 4-20ma signal, ie pressue is high(20ma) slow the motor down, pressure is low(4ma) speed motor up.
How do I configure it to hold at a desired setpoint, say I want the system to run at 18psi or 9.75ma whether the is 1 tank chilling or 12 tanks.
With more tanks chilling it will require a high pump speed to maintain the desired pressure and vice versa.
Is the powerflex able to do that kind of scaling?
Jon
Correct me if I'm wrong guys, but according to my magic PF4 book: A112 and A113 is your scaling, set A112 to 100%, A113 to 0% to reverse scale. A112 is the low side of 4-20, and A113 is the high side.
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
70
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
91
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
91
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
88
