PowerFlex 40 - best way to set the IP Address on a 22-Comm-E
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I’m trying to get our maintenance staff to set the IP Address for a 22-Comm-E
card for PowerFlex 40 drive . I usually use BootP , but is there a way you can use the built in HIM on a PowerFlex 40 to set the IP Address on the 22-Comm-E ? Shame on me if I overlooked this .
Thanks so much in advance
Thanks . I read that manual , but within the procedure with the HIM , it did not seem like it followed thru to the IP Address entry . I will try it tomorrow.
Thanks again ,
The HIM module is actually connected to a tiny serial "DSI" network with both the VFD control board and the 22-COMM-E.
Follow the steps on page 3-2 to switch from connecting to the Drive and its parameters, to connecting to the 22-COMM-E and its parameters.
The IP address itself is parameters 3,4,5,6 of the 22-COMM-E.
Be sure you enter a compatible Network Mask and Default Gateway, and disable BOOTP.
Good Evening , What would be the best way to reverse a motor using a Powerflex 525 drive in RS Logix 5000 ? The drive is running in one...
4,005
Good Afternoon , We still have a number of Powerflex 70 drives throughout the plant. Many are being controlled by DeviceNet that I plan on...
6,736
We are going to start a new proyect which involve the use of 5 or 6 drives, an we want to know what is the best network for the powerflex drivers...
5,088
Fairly new to the drive so apologise for the layman terms. Textile machine uses PF525 VFDs to control motors. The speed of the drive is currently...
140
Hello Everyone, I want to upgrade the firmware of Powerflex 40 from 5.001 to 6.002 can anyone tell me how can I do that?
76
