Powerflex 40 Can't Upload Config File
raamakoti
Apr 2021
home
20
I am trying to upload the exiting powerflex 40 config file and it would not let me. The only choice I see is create database. However when I press that it shows progress bars for 3 different things and still comes back to attached "Drive" tab screen.
Any suggestions on whats going on?
Here is the screen where I could not change the revision
https://drive.google.com/file/d/1TrgKT6Tj10KDEi9Lk4NnUtLxCI3zychZ/view?usp=sharing
Under RSlinx browse it shows version as 6.002
Update I figured it out.
I had to delete the module, add new powerflex 40-E module with same IP address and name. Then it allowed me to upload the parameters from the drive.
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,787
So we replaced a PowerFlex 525 drive with the exact same model. I was told that once it is in and given the old IP address, you can upload the old...
24
14,340
Hi, I have a Powerflex 700 VC (actually a number of them) all connected via RIO using a 20-COMM-R back to an SLC 5/03. I need to install a...
2,453
Hello, Recently one of my customers had an Powerflex 753 drive without the Ethernet adapter. Is there an way to connect with the drive with CCW...
1,759
I have a PowerFlex 753 drive connected to my laptop via a 1203-USB adapter. When I connect to this with CCW and try to upload from the drive, the...
5,589
