powerflex 40 multi drive: invalid size connection
italo2008
Feb 2009
Padova
95
I have a problem with 2 powerflex 40 connected via 22-comm-E (multi-drive) with a compactLogix L32 controller. I'm sure I've correctly set all communication parameters (number of nodes, addresses, baudrate , the dip-switch on the card and so on (it's not the first time I have this configuration). In sigle drive mode the 22 comm e works, but in multi drive mode I can see only the port 0 and the drive connected to this. The PORT led is always flashing red and I have the code error 16#0109 invalid connection size. I've check cables and parameters but nothing..........
someone can help?
I had to replace 3 PowerFlex 40 multi-drives that each had 3 PF4M daisy chained off the DSI port. The PF40s had comm-e cards installed for...
2,446
I have a machine with a CompactLogix ver20 and PowerFlex 40 multi drive node. That PF40 has a Comm-E ethernet adapter and has four PowerFlex-4Ms...
1,893
Hi All, Tearing my hair out! I have had this working in the past but cannot figure out what is wrong now! Simple set up. PF 525 set up as...
4,131
System: 1769-L23E Processor PF40 mounted with an 20CommE qty 4 PF4s daisy chained RS485 to PF40 I keep getting an F071 which is called "Net...
4,018
I am attempting to perform a "scattered" read of parameters on a Multi-drive setup of 1 PF40 and 4 PF4 drives over EIP from an L23E. The 22-COMM...
2,129
