Powerflex 400 from series A to series B
boardmaker
Mar 2007
missouri
106
I have a controls system that has multiple PF400's. All of them are older series A drives. They all communicate with 22-comm-e's with a Compactlogix.
I noticed that my new spare drive that I keep on the shelf is a series B and all the rest(in operation) are series A. Just wondering if there might be any issues plugging an older 22-comm-e into a new series drive? I've been looking around but haven't found any info. Normally I wouldn't worry about this, but it's AB so who knows if I'd have to do some firmware upgrade on the comm-e.
These swaps typically happen during the most inconvenient times so I'm just trying to make sure there isn't pain headed my way.
**wanted to add that it would also be a drive firmware jump from 7.01 to 8.01
you should contact your local ab rep.
they are supposed to have a drives specialist to help with your question.
you can also open the series b unit and find tech phone number to help with your questions. tell them how many series a drives you need to upgrade over the next few years.
james
Hello I have a powerflex 400 of 25HP for a 60amp 25HP motor, the motor have a belt that move the clarifier of milk. It is a process that requires...
4,184
Does anyone know what the RJ45 pinouts are for the DSI port on PowerFlex 400 drive? I want to connect a Modbus 485 master to it. Thx
2,778
Gentlemen; Have a bit of an odd one - a customer has a PF400 running a vacuum pump motor. They said they changed the motor out 3 months ago, and...
30
12,529
We have a F04 UnderVoltage fault on a PowerFlex 400 drive, which does not want to reset. It was running normally for months. We checked input...
6,153
A customer has a 25hp well pump on a PowerFlex 400 VFD. Supposedly this has been happening for a while, but I offered to look into it. The...
4,039
