PowerFlex 400 DSI Port
KirkC
Aug 2015
California
55
Does anyone know what the RJ45 pinouts are for the DSI port on PowerFlex 400 drive? I want to connect a Modbus 485 master to it.
Thx
Should be in the manual. They also have an RJ45 kit with RJ45 connectors that have screw terminals and the resistors. I'm not gonna look it up because it should be in the manual.
I spent 2 hours reading manuals. No, it is not the manual. That is why I asked. The DSI Cable Manual kinda identifies pins 4, 5, 1, and 8 as doing something, but not what they do.
After some experimenting the answer is pin 4 = D+, pin 5 = D-. I suspect pin 4 is jumpered to pin 1 and pin 5 is jumpered to pin 8 for the purpose of daisy-chaining.
Why don't you spend the 20 bucks or so and get the proper RJ45 kit for the task. Sounds to me like you want to make your own. How much is that costing?
Pins 1 and 8 are identified in the diagrams on page D-2 of the PowerFlex 400 User Manual solely to orient the reader's view of the plug.
Data B = DSI plug Terminal 4
Data A = DSI plug Terminal 5
Chassis Ground / Data Common = Discrete Control Terminal Block Terminal 19
Thanks Ken.
I will get the AB connector, but I needed to know what the pins were assigned to because I am not connecting to an Allen Bradley master.
Use any connector you like; those are just convenient and available from your A-B distributor.
I don't like it that DSI was built without an isolated 3rd conductor for the signal reference (like DH-485 users), but that's the way it is.
Hello I have a powerflex 400 of 25HP for a 60amp 25HP motor, the motor have a belt that move the clarifier of milk. It is a process that requires...
4,184
Gentlemen; Have a bit of an odd one - a customer has a PF400 running a vacuum pump motor. They said they changed the motor out 3 months ago, and...
30
12,525
I have a controls system that has multiple PF400's. All of them are older series A drives. They all communicate with 22-comm-e's with a...
1,564
We have a F04 UnderVoltage fault on a PowerFlex 400 drive, which does not want to reset. It was running normally for months. We checked input...
6,153
A customer has a 25hp well pump on a PowerFlex 400 VFD. Supposedly this has been happening for a while, but I offered to look into it. The...
4,039
