Powerflex 525 Control Module
Snap25
Dec 2014
Michigan
237
I stole a 525 control module (Cat no. 25B) and put it on a drive from another VFD to get a process up and going.
The VFD the control module was on had a different HP rating so I have a mismatch. I've done this before via the USB port.. but for some reason I cannot get any of the 525s USB driver to work anymore...
Anyways, I'm trying to change the driver properties via Ethernet. I use the boot tool to change the IP and all that, I can communicate and change parameters but I cant change the HP ratings and other properties online. I go offline, change the properties to the new VFD hp and try to download.
It prompts a warning saying the properties are different than the control module and I click continue and nothing changes!
I tried it in the workbench program and studio.
Any ideas?
Primary objective is to get the mismatch resolved..
secondary objective, why the hell cant I connect to any 520 series with a USB anymore. My laptop goes looney every time I plug it in. I can see the drive, takes 7 minutes to pull up the file page and then it freezes everything once I click on the powerflex USB application
I was able to get the USB application to work in safe mode.. It was still slower than molasses and very glitchy
So our Powerflex 525's are set up to allow REMOTE operation from PLC through network. But if network is lost we want to be able to run in LOCAL...
571
Hello All, I am working with a powerflex 525 trying to get multiple speed references. I got it working on my bench and then I went out to the...
1,090
Hi, I'm looking to see if there is a solution for an application I'm attempting. I have a PF525 running a pump. It is primarily hard-wired...
1,543
Quick question for all. Looking at upgrading my plants VFD's to PF525 however all the current plant controls are 120VAC. Can the PF 525 be...
3,788
Hi All. I am trying to commission a Powerflex 525 Drive but currently only have access to +24VDC, I simply want to assign Ethernet/IP Address...
18
7,770
