PowerFlex 525 Ethernet Controlled
Tmac2490
Jun 2017
Nova Scotia
We have 5 Powerflex 525's being controlled over the Ethernet. All are tied to same managed switch. In the RSlogix 5000 code all the modules are set to a RPI (Requested Packet Interval) of 5ms.
Would having such a quick RPI potentially cause equipment to miss start commands?
Thanks,
Tmac2490
I am with Janner. Unless you have some kind of ultra fast process that you are controlling there is no need for a 5ms RPI. I just installed a new 525 and my RPI was 100ms. I was just controlling a pump. You are taking a chance of overloading your Ethernet with unnecessary traffic. I would evaluate your needs and make the RPI reflect those needs.
You need to make sure that the stop signal is removed from the drive before the start command is given, I usually do this by setting Parameter A574 (Rdybit Mode Cfg) to either standard or enhanced and then have the drive ready bit in series with the start bit, this way the ready bit will not be true if the stop bit is asserted.
I think I set the A574 to enhanced but will need to check with a drive or when I am back onsite later in the week.
Alan
Hi guys! We have a big project at work where we are migrating from 1305, 1336, 160, 70, and 40 drives to identical PowerFlex 525 models. Most...
903
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
608
I am looking for some help with a project that I am working on to finish my maintenance apprenticeship. Any help would be greatly appreciated. My...
3,319
Good Morning , I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet...
1,776
Good Day Guys, I currently have a set up with 4 pieces of a 22-comm-e with 20 powerflex 4. I would like to move away from the daisy chain...
2,466
