PowerFlex 525- If Ethernet/IP is selected , but I want to control speed via.4-20 ma.
Aug 2016
Virginia
343
Good Morning ,
I have a PowerFlex 525 , that most controls are set for Ethernet/IP. I would like to control the speed with 4-20 ma. from a output card on another PLC. I changed the Speed Reference from Ethernet/IP to 4-20 ma. , but the Ethernet from the MicroLogix 1400 is still controlling the speed. What do you think I am doing wrong ?
Thanks in advance,
What specific parameter(s) did you change in the 525?
Did you change parameters 47, 49, 51? Are you selecting speed reference sources? I would set 47, 49, 51 all to 4-20ma Input, just in case something is inadvertently trying to switch speed sources.
Hi guys! We have a big project at work where we are migrating from 1305, 1336, 160, 70, and 40 drives to identical PowerFlex 525 models. Most...
889
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
600
I am looking for some help with a project that I am working on to finish my maintenance apprenticeship. Any help would be greatly appreciated. My...
3,291
Good Morning , I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet...
1,766
Good Day Guys, I currently have a set up with 4 pieces of a 22-comm-e with 20 powerflex 4. I would like to move away from the daisy chain...
2,463
