toddp65
Hi all,
Small panel built with a micrologix 1000 and a 525 drive. The micro is simply for start/stop/control of power flex and some lights and switches. The Drive is set up on start mode 1 for the local speed pot and PIDLoop1 via a 0-10 volt pressure transducer. It's set up on speed reference 2 on TB5. I have the sources set correctly but when i enable the PID it coasts to a stop. My transducer is reading about 4 volts at 100 psi (it's a 0-300 psi range transducer) and my i have feedback and ref set to the 0-10 volts. I have the setpoint at 50 hz.
Any help appreciated.
Thanks!
Thanks!
