Powerflex 525 PID Controll for a Pump in a Hot Water Set
You probably want a small deadband around your pressure setpoint as well. Assuming it isn't critical to be right on the money.
+1 on the deadband, there is a parameter for that. Also, think about failure mode. If the pressure sensor fails, and thr drive sees 0mA on the input, do you want the VFD to go full speed or to stop? If you want it to stop, you may want to invert the control action, and also invert the pressure transmitter signal (many IFMs can do that). Otherwise there is a parameter in the drive to disable itself if the analog input falls below an adjustable level.
Any idea off hand what that parameter is to disable itself if the input falls below? Other than that I have it all good to go just was wanting to have that ability for if the IFM dies.
Hi all, Small panel built with a micrologix 1000 and a 525 drive. The micro is simply for start/stop/control of power flex and some lights and...
2,129
Hello, I take part in commissioning of process station with lobe pump. Speed of the pump is controlled by PowerFlex 525. A customer requirement...
5,549
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
247
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
482
