Powerflex 525 startup wizard error
jakeparsons03
Jun 2017
Indiana
78
I keep getting this error when getting to the "direction test" portion of the startup wizard. It says "received an error response to a control message. This may have been caused by a loss of communications or network scanner may have begin controlling the device". None of those cases are true. Has anyone ran into this?
Knowledgebase says this is a known problem.
See article QA45452.
Unfortunately this is not the same error. I have tried isolating this vfd to its own project with factory default parameters and it still gives me the same error, so I know its not my program. At what point do I say that the drive is faulty?
The only way I can get it to run is to put it in override and command it from there.
Old thread but I was having the same popup issue when getting to direction test.
Take the controller offline and put it into remote program mode.
I have a powerflex 525 that runs on 220 VAC. I wired up power and got into some parameters, but for the most part left it alone. I then got a...
1,971
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
247
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
481
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
239
