Powerflex 700H Dnet FW 1.006 help
MoPete
Dec 2018
canada
Hi!
I have a PF700H, 600V, 590A.
Its on DeviceNet.
Produce Type: 121
Product code: 45620
Revision: 1.006
EDS File I think I need: 00010079B2340100.EDS
Problem is, not even Rockwell seems to be able to supply me with EDS file for Rev 1.006. Rev 2.0 is different at the parameter level and fails.
Anyone have this old version I can use please?
I know I can update the firmware on the VFD but I am not onsite, and requires a serial connection....
Thanx!
I couldn't find it either, and this probably won't help, but (From the AB site regarding finding EDS files):
Contact Technical Support at 440.646.3434 if you have difficulty locating an EDS file.
I had this exact same problem.....ended up calling Rockwell Technical support and they found the correct revision in an Add on Profile.
Hello, Currently I am controlling the Powerflex 700H via Ethernet and everything is working well. The client is wanting Auto/Manual function...
1,865
So, the background to this issue is yesterday this VFD got a cooling fan fault, every fan inside was working properly and was clean. We have no...
1,694
Hello I have a Powerflex 700H 300hp pn:20CD385H3ANNBNB0 Ver. 3.001 I am using a 20-comm-e to talk to this drive. I have the drive configured with...
1,989
I was looking at parameter 190 for the 700h and I trying to figure out if this would disable the option for a technician to walk over and put a...
2,062
