Powerflex 700H Ethernet setup help
iggy
May 2007
FLORIDA
198
Hello I have a Powerflex 700H 300hp pn:20CD385H3ANNBNB0 Ver. 3.001
I am using a 20-comm-e to talk to this drive.
I have the drive configured with the ip address, it is added to my i/o tree and that is all fine. I am using Logix 5000 v.20.04.
The problem I am having is I cannot find in the book which pram. to set to start the drive from the network. I have used PF40, 400, 523 they have a network option in the pram. I have no exp with the 700 drives. I can see where I can send it a speed ref from the network which works fine. Now the only way to start the drive is from the HIM.
Any help would be much appreciated.
Hello, Currently I am controlling the Powerflex 700H via Ethernet and everything is working well. The client is wanting Auto/Manual function...
1,862
Hi! I have a PF700H, 600V, 590A. Its on DeviceNet. Produce Type: 121 Product code: 45620 Revision: 1.006 EDS File I think I need...
1,451
So, the background to this issue is yesterday this VFD got a cooling fan fault, every fan inside was working properly and was clean. We have no...
1,694
I was looking at parameter 190 for the 700h and I trying to figure out if this would disable the option for a technician to walk over and put a...
2,061
