PowerFlex 700h reverse options
remullis
Oct 2012
Georgia
179
I was looking at parameter 190 for the 700h and I trying to figure out if this would disable the option for a technician to walk over and put a screw in reverse.
We are running a screw that locks up from time to time, our techs are asked to go out and reverse at the HIM, I want them to have access to certain things but I would like to disable the reverse option. If parameter 190 is the option to do this, can it be done while the drive is running?
From the help file on Drive Executive, the drive must be stopped to change this parameter, when set to reverse disable, to reverse the drive you will either need to change this parameter or swap the motor tails.
Alan
But yes, once put into that Rev. Disable setting, it will prevent someone from running it in reverse via the drive inputs or HIM. They will get a fault that says "Bipolar Conflict" if they try.
Hi! I have a PF700H, 600V, 590A. Its on DeviceNet. Produce Type: 121 Product code: 45620 Revision: 1.006 EDS File I think I need...
1,451
Hello, Currently I am controlling the Powerflex 700H via Ethernet and everything is working well. The client is wanting Auto/Manual function...
1,863
So, the background to this issue is yesterday this VFD got a cooling fan fault, every fan inside was working properly and was clean. We have no...
1,694
Hello I have a Powerflex 700H 300hp pn:20CD385H3ANNBNB0 Ver. 3.001 I am using a 20-comm-e to talk to this drive. I have the drive configured with...
1,989
