PowerFlex 755 set defaults
janasamara
May 2017
Portugal
20
I'm trying to reset the driver to factory defaults. In the MEMORY folder I choose the set defaults and select this port only. Then press ALL.
The following message appears : DPI ERROR Object State Conflict.
Does anyone know why this is happening?
found this :
Rockwell Automation, Inc. [2012j, p. 66–67] requires the PC tool or the control
panel for parameter reset. With the DriveExplorer software, the parameter reset is
initiated via: Actions—Non-Volatile Memory. . .—Load defaults. . . However, it did
not work for the safety module. (The attempt resulted in the mysterious message:
“An error occurred during NVS command.”) Also attempt to reset the safety parameters
with the control panel was unsuccessful (due to “DPI Error: Object State
Conflict”). Parameter P7 Reset Defaults of the safety module must be used to reset
the safety parameters [Rockwell Automation, Inc., 2012a, p. 123]. Which was possible
only after the safety configuration was unlocked and P6 Operating Mode set to
“Program”.
does that help?
See attachment...
Thank you for response.
But don´t help me because these parameters you mentioned are Safe Speed Monitor Option Module and I don't have this module.
Okay, I'm beating my head against a CIP wall here. Does anybody know how to read and set the time from a Logix PLC over Ethernet? It looks to me...
3,257
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
275
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
139
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
228
