Powerflex 755 Start/Stop/Run
einnh
Mar 2014
New England
275
Quick question?
What is the difference between START and RUN links when controlling Powerflex755 through Ethernet/IP?
When you wire the drive in 3 wire mode, you use the Stop and Start inputs.
When you wire the drive in 2 wire mode, you use the Run input only.
When the run input is off the drive is in stop mode.
Alan.
I just did a project using a PF 753 that I was controlling via Ethernet IP. Ken Roach has posted several ideas about how to best control a PF via Ethernet IP.
Basically, to start the drive set the LogicCommand_Start bit to 1 until the DriveStatus_Running is true. Set the Reference to the RPM or Hz you want.
To Stop the drive set the LogicCommand_Stop bit to 1 until the DriveStatus_AtZeroSpeed bit is true. I also move a 0 into the Reference.
This method has worked perfectly for me. Good Luck.
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
276
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
139
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
228
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
433
