PowerFlex 755 T SOS
Tmills407
Sep 2023
Oklahoma
I am having an issue with my 755 powerflex in one of my production lines.
I currently cant network with it whether i am connected via direct or across the plc network. Normally i can see it when online check parameters exc. i cannot as of now.
It is my main DC bus supply,i cant put an ip tool on it to ping it or ping it on the pc. it shows a "ALN-56.1 PF755T DC BUS SUPPLY ethernet/ip fault" on the HMI and on the H.I.M. (755) it shows a "SW Bus Over volt" fault code 13068
Im under quite the pressure by production and im not sure of my next move.
SOS
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
278
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
173
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
140
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
228
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
434
