Powerflex 755 vs Powerflex 700
Nandraj
Dec 2016
India
51
Dear All ,
I have powerflex 755 110kw drive running on devicenet node add 1 but now its got bad , I wanted to replace it with powerflex 700 110kw Can i just add same node and plug and play option works ?
when i used to have armourstart AB drive 1hp to 5hp it use plug and play i used to put same node address in devicenet and just plug and it starts i no need to do any configuration only in scanner module it used to asks for revision change . so i wanted to know that Can powerflex 700 can works plug and play in replace with 755
please hop you will help
thanks ,
nandraj
So you want to replace a newer drive with an older one? Is that because the PF700 is all you have available? That’s the only valid reason I can think of. And if that PF700 has been on a shelf unpowered for a couple of years, you will have to put it through a capacitor reforming procedure.
Assuming that because this is DeviceNet you have a PLC, you will have to change the AOP and probably some of the programming in your PLC because the I/O is different between the two.
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
319
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
193
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
151
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
237
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
455
